1 - 8 of 8 Posts
Banned
Brian and others, has anyone diagnosed what color green Bolens used on the HT series "forest green"?
I will match it if no one else has done the leg work.
This is for OldBuzzard's HDT1000.
Thanks!
Ben W.
  • Like
Reactions: OldBuzzard
Premium Member
Hay Husky!
Is that a Johnson 14 on there?
I see no rear weight box? Just wheel weights are enough?
Thanks for the rustolium paint names.
I'll be needing that as I've just about worked through my mechanical issues!
Joe
Blackjackjakexxix
Hey guys try this,Sherwin Williams years ago had this in there paint charts called Bolens green,mixed in 2nd Dimensions 5.0 acrylic enamel,can said the following UFN 3873401 5A-33863-00-A dark green,code 173-6796 CB#: 3873401,a friend of mine gave me this,he just painted a dump cart for his HT-23,the match was right on,he took a NOS HT-23 bracket and checked it and right on,if you need any more info,I'll try to get it for you
Hay Husky!
Joe
Yes that is a Johnson 14. Those rear tires are filled with heavy foam they came off of a forklift. They weigh in at 175lb each. Plus the 50lb weights make them 225lb each. They are great I don't need a weight box and all the weight is on the ground, not on the rear transaxle. I feel this is the best way to put weight on the back.
  • Like
Reactions: Rock farmer
1 - 8 of 8 Posts
