1 - 7 of 7 Posts
Hello all, first off let me say that I posted for the first time last night and was impressed with how friendly and helpful everyone was . Now to the HT20 problem. Last summer i was using the old girl pretty hard on a hot day and she started running rough (normally purrs like a kitten). Let it cool down and had no problems after that. Been trying to figure out why ever since. Anyone ran into similar problem, or have any ideas? Many thanks
Old, but not dead -- yet!
Sometimes ignition components will breakdown if subjected to too much heat, but be OK when cool.
Another cause of the rough running may be fuel percolation (boiling) or vapor lock caused by excessive heat. ....Today's gasoline is more prone to these problems.
Keeping engine cooling fins clean of debris is the most important step in preventing an engine from running excessively hot.
Discussion Starter · #4 ·
thanks bolens 1000, i will check that out this weekend. pretty good with the wisconsin/tecumseh motors, not much experience with koehler. looks like i have some homework to do
Yeah, Ever since they went to the E10 Ethanol, My Bolens will not restart when they are hot. Supposedly the ethanol makes the engine run at higher temperatures, I either have to wait it out until they cool or I give them a shot of carb cleaner to get them going again. I have been adding some anti ethanol additives and it seems to have helped.
Thanks Bruce Dorsi, I wondered about maybe vapor lock. the engine covers on that motor seem to lay right against the head. did not look like the best design to me. One more thing, thanks for your help and let me know if i am not using the forum correctly (replying, posting, etc.) this is new to me
Welcome shinklem, If the problem stems from the motor over heating. You may want to make sure that all of your heat shields are in place. On these older tanks it is not uncommon to be missing one or more of these items. and not only are they designed to keep heat away from the motor they also are important for moving cool air around the motor. just another thought. :)
Again Welcome!
1 - 7 of 7 Posts
