1 - 9 of 9 Posts
So, I'm assuming this is a carb issue..
My ht20 first, if I fill my fuel tank past carb height, it flows out. Assuming this is a needle and seat or float issue.
Most importantly, when starting, it needs to turn over much longer than what it should to fire. I would say, 10 seconds minimum. Unless the tractor was just running. Ambiant temp doesn't change this. I think this is also a carb issue?
Thanks in advance for the help as always
My 1250 was the same way. If fuel was above carb, it would start. replaced the carb and it solved the problem. You can also by-pass the pump to see if it will run with fuel higher than the carb.
1 - 9 of 9 Posts
