1 - 9 of 9 Posts
This is a thermostart system usually found on Perkins and Ford diesels. Definitely a worthwhile upgrade if your going to run the machine in the winter. the thermostart ran about 20$ and about 8$ in brass T and hose barbs. i had the relay and wiring in stock.
Watch out winter!
Ill add some pictures later.
  • Like
Reactions: LPBolens
Nice addition! I had never seen one for a small diesel before.
Discussion Starter · #3 ·
That is a real beast to get started in the cold. I'm spoiled with my Yanmar with glow plugs. It lights right up even in the coldest weather here. I do treat my fuel though. They tell me at the JD dealer that that is very important. I'm not sure how true that is but I've had no trouble the last 3 years while using treated fuel.
A retired army friend of mine spent his career in tanks. He tells me that in the old days when it was really cold they used to light a small fire under the engine to warm it up before attempting to start them. Your solution is much more practical for a GT.
Can you explain how it works ? Al
Discussion Starter · #6 ·
Al, Think of it as a cigarette lighter. the element heats up when electricity is applied to it. the heat then opens a valve which allows diesel fuel drip onto the element producing a small flame. The heat and vapors produced by the thermostart helps the engine start.
Frank
Thanks for the explanation . Never saw anything like that , Al
Thanks for the video.
Our old Massey Super 90 farm tractor uses the same type system & works really well. When the spurt of diesel ignite, you can hear a "faloomp"sound. On the Massey it's OE, and to energize the igniter you turn the key to the left, then when time, turn the key to right to crank.
1 - 9 of 9 Posts
