1 - 7 of 7 Posts
Deceased
anyone know how much one weighs with 26-12.00x12 and a 3pt. i found one and want it bad but its a 2500 each way trip... why are they so hard cold starting is there anyway to fix that. any help would be great thanks, sam
Deceased
It should be close to the same as the HT23. It's shipping weight is listed as 1,100 lbs.
By the time you add oil, trans fluid, fuel, and the 3-pt you are probably in the 1,200 Lb range.
If the rear tires are filled with Rim Guard or CaCl, that would be another 220 lbs to add. If filled with windshield washer fluid it would be 160 lbs total.
The diesel MAY be a bit heavier than the Kohler twin, so if you figure it at 1,500 lbs you should be safe. I doubt that it would weigh more than that.
I've towed mine with a F150 and had no problem towing it. As long as you have a trailer with at least a 1,500 lb payload capacity you should be good to go.
As for the hard starting, I haven't found that to be a problem, but I do have a 'cold start' system.
bhts has one, and since he started using the compression release when starting, his has been starting in cold weather for him as well.
It probably wouldn't hurt to use an anti-gell addative which also raises the cetain number. Raising the cetain number will help with starting in cold weather as well.
My HT20D has a Calrod-type heater coil inserted into the air chamber around the heads. It runs on 110V. This is not a glow plug, but kind of works like the element on an electric stove. It appears to be either a factory option, or it was dealer-installed. I have seen this set-up on more than one HT20D, which leads me to believe that it was not a homemade installation.
Tractorfanatics.com
Intake heaters are becoming more popular again in the construction industry. Disasterous when ether is introduced when someone doesn't know better. Big flame-out.
Sam, you could just leave it run when you start hitting colder air on the way back. They hardly burn any fuel at idle.
Deceased
As hard as parts for the Wisconsin/Ducati engine are to come by, I wouldn't use ether with one on a bet.
The Attachment Guide shows that there was a "Cold Start Kit" for the HT20D, but I have no clue as to what it was.
Here's what my 'cold start' option looks like. I don't think that it's the actual Bolens one, but something that a PO installed.
[sharedmedia=core:attachments:45152]
I'm guessing that those are a pair of glow plugs. All I know is that if I hold the switch on the dash for 10 secs or so, my 20D will fire up at 28* with no problem.
That's how mine is set up Doug, and it still works. When I bought mine it even had the cord to plug it into 120 volt. I had no idea what it was at first when I found it in a 5 gallon bucket with the tire chains.
Bob's Lawn and Garden LLC
Thats what i have on mine also just missing the cord for it.
1 - 7 of 7 Posts
