1 - 6 of 6 Posts
Make Stuff Up
I'm still slowly working on my HT23, I just realized today (maybe I should of checked sooner) that there is no compression, I'm guessing the valves are stuck???
I bought this garden tractor from a friend and it had been siting for several years. Although he said the engine ran great when it was parked, the engine was covered so I'm guessing it isn't stuck very bad.
I'm not really looking into a complete rebuild and I don't have the equipment to grind the valves and ect.
If anyone has any ideas I would appreciate it.
Thanks
Take the lifter covers off and spray very generously with PB Blaster or whatever you use. Pull the spark plugs and spray generously in the cylinder. I then roll the engine over by hand and see which valves are stuck, most likely it's the exhaust valves. I use a thin slotted screw driver between the lifter and valve to see if I can get it to open any, if so usually it will move back and forth after that. Keep working them by hand until they move freely. Good Luck !!
  • Like
Reactions: BTS and Alc
I would do a decarbon with Seafoam after you get the valves loosened up. I had this happen in a MF 8 (HM80 tec. ). I simply sprayed penetrating oil into the cylinder and let it sit then turned it over. It did the trick. It had been sitting for 5 years.
Make Stuff Up
Discussion Starter · #5 ·
I filled the cylinders full of liquid wrench two days ago, rolled the engine over by hand and didn't have any compression at all. I let it sit and then I refilled the cylinders again with liquid wrench and then rolled it over again by hand and what would you know it now has compression!!!!!
I stuck a battery on it and the compression seems to be really good.
Now I just need to finish rebuilding the carb, put in new plugs and points in it. Then try to start it!
Cant wait,
Thanks again for the help :worshippy1: :thumbs:
The valves on my HT23 were sticking. They had some major carbon build up on them - but they cleaned up nicely. I soaked everything and used plenty of seafoam and various other stuff to get the hard carbon cleared off the valves etc.
1 - 6 of 6 Posts
