This particular tractor calls for 10w 30 motor oil in hydraulic system.Most call for ATF, so red is likely right. You can use other oils though.
Same pump as many other makes that call for ATF, so nothing is hurt with the ATF in there. 10w30 is better for warm/hot weather or older worn systems, so a simple oil change will take care of that. I doubt very seriously you have anything to worry about.This particular tractor calls for 10w 30 motor oil in hydraulic system.
So now my problem is I don't really know what it is and I'm low on fluid. U think its just ATF?Same pump as many other makes that call for ATF, so nothing is hurt with the ATF in there. 10w30 is better for warm/hot weather or older worn systems, so a simple oil change will take care of that. I doubt very seriously you have anything to worry about.
Probably back when that hydraulic system was built. A lot of advancements have been made in lubricants in those years. If one can use hydraulic fluid, or ATF in a $250K tractor why won't it work in a $1k tractor ? ?This particular tractor calls for 10w 30 motor oil in hydraulic system.
Will it get the tractor to move? Why yes. But is it actually the right choice? For some reason the hydro release plunger blew out and leaked oil everywhere. One guy thought maybe using hydraulic oil built up pressure? Who knows? But if my car suggested using 10w 30 I don't think I'd run whatever would work per say. Just trying to get the right answer.Probably back when that hydraulic system was built. A lot of advancements have been made in lubricants in those years. If one can use hydraulic fluid, or ATF in a $250K tractor why won't it work in a $1k tractor ? ?
IH/Cub Cadet Hy-Tran (a red hydraulic/ATF type lubricant) was used/spec'd in the Cub Cadets that had the similar Sundstrand hydro unit in them. I had a car with a manual transmission that spec'd ATF as the lubricant. Either will work fine in these machines. I like to stick with what Ariens spec'd and run with the motor oil. If I got a tractor that had a recent change/fill with ATF, I would leave it.Probably back when that hydraulic system was built. A lot of advancements have been made in lubricants in those years. If one can use hydraulic fluid, or ATF in a $250K tractor why won't it work in a $1k tractor?
FYI...If you remove the hose at the bottom of the front of the trans, you will get most of the oil out.In a Wheel Horse it is very difficult to remove all the fluid when draining trans. Therefore you would possibly be mixing two different fluids that are incompatible. How is your situation?
