1 - 13 of 13 Posts
I recently changed the filter and fluid in my Snapper 1650 and used type F ATF. now it seems to be a little down on power. Is this the correct fluid to use? If not, could it be causing the lack of power?
Can still get Type F? Thought newer types took over now. F is one of thinnest available when used, maybe should be other. Some tractors take Dexron, a GM product, and others just take motor oils. Check a manual as noted. Type F seems out of date by the time this tractor was made?? Even in some cases, the Hy-Tran fluids used in most modern tractors, bought at Farm stores is maybe a better bet.
Did you change the filter at the same time? If not I would swap it out to start. Here is a link to a site with specs on filters: https://sites.google.com/site/mac102004/air-oil-filter-guide/massey-ferguson-filters
As for which fluid to use, I've found two that are specifically compatible in replacement of the M-1110 fluid which is listed as spec for the Snapper/Massey 1650:
Amsoil Synthetic Tractor Hydraulic/ Transmission Oil
SynGard™ Synthetic Tractor Hydraulic
I just got my 1650 a little while ago, and the fluid is on order from Oilmart in Winnipeg, MB. I went with the Amsoil Hydraulic Transmission Oil and will be putting it in shortly. The filter I ordered from NAPA in Winnipeg, P/N 1410.
Any good quality Tractor /Hydraulic fluid that meet J20A specs is fine.
Here is some more info on the filters.
  • Like
Reactions: cchap45 and Cvans
Discussion Starter · #7 ·
thanks everyone! I did change the filter and I'll change it again when I swap out fluids.
You can also use 30wt motor oil in hot weather conditions and or heavy duty use.
Discussion Starter · #9 ·
I have two 1650's, the one that i just changed fluid in seems considerably slower and less powerful than the tractor with old fluid in it. Is that because of the type A transmission fluid I used? or is the pump just weaker (worn)?
Were do we find the type F today?
Maybe Dextron IV?
Type F was made for transmissions with Brass in them. Ford Automatic Transmissions in the early 50s thru the 70s.
As does our newer Tractors. Tractor/Hydraulic fluid will play well with the brass plates in our hydros.
I use it in all my Sundstrand and Eaton Hydros with great results. When we get a chance we will be looking at the rear axle on the 4855 because of some lack of power at the Mackville pull. Will fill you in when we get inside.
1 - 13 of 13 Posts
