1 - 9 of 9 Posts
G
so i was thinking on which hydro fluid to use for my bolens sundstrand, super tech isnt going in her come hell or high water, one of which is hitting me tomorrow. and people say john deere hygard works well. has anyone tried this and how much does it cost. knowing its johndeere i can bet its not cheap.... but supertech is just wallyworld branded crap in a bottle.
Premium Member
Others will know better then I but I don't think you want hydraulic fluid for the Sundstrands.
NO hydraulic fluid! Either ATF or straight 30wt motor oil.
G
Discussion Starter · #5 ·
but now the way i read it on another site it was rated equivelent to benzoil thl 19 which is what the large frame repair manual says to use.
G
Discussion Starter · #7 ·
I think Hygard is for trans/hydraulic applications, so it's a lot different than straight hydraulic fluid. The film shear strength in trans/hyd fluid is much greater than with straight hydraulic fluid. So I stand by my "no hydraulic fluid" statement, but needed to have said "no straight hydraulic fluid".
Straight hydraulic fluid can foam believe it or not. In the Case hydriv systems, straight hydraulic fluid will foam so bad they will buck/jump, and act completely crazy. I know because several years ago, I found out the hard way.
G
Discussion Starter · #9 ·
yeah i bet this stuff is expensive, plus i know i have pin hole in the bottom of my current oil filter where it looks like it got bumped by something so i know i have a slow leak on my filter so ill need a new filter. this wont be a cheap week.
1 - 9 of 9 Posts
