1 - 20 of 33 Posts
ill start with this my dad had a mf 12 when i was lil and i loved it so i thought why not my dads ran great.i know i know not very smart to think .well the guy i traded it for said all it needed was the fule tank cleaned.ok no big deal.so i get the tank cleaned went to try to start it dead battery.now a bad starter. now no spark.the only thing i know its a hh120 motor 12 hp i think. i would realy like to find out the year of it and what might be wrong with this tractor.PLEASE any suggestions? thank you
frustrated dad of 6
ps ill try to get some pics of the beast soon
Welcome to the forum Dad of 6, glad to have you here. Sorry you are having problems with your new tractor but lets see if we can help you out. Have you taken care of the dead battery and the starter problem and now it rolls over with no spark? The dead battery may come to life with charging. The bad starter problem may be just a bad electrical connection somewhere. Might be best to take the starter off and have it tested and go from there. The no spark could be just a bad spark plug. The very early Massey 12 garden tractors had points for the ignition. Most of them had the solid state ignition and there were 2 styles of them. No spark could even just be a grounded out wire.
Let us know what you have done so far and then we will go from there.
If you get a chance hop on over to the new member introduction forum and post an introduction there. Mike
  • Like
Reactions: Dad of 6
:ditto: on everything that was said above, & :welcome: to GTTALK.
The model & serial # would be a help in determining year, when you're sitting on the tractor it should be by your left knee (under the dash).
If the tag is missing, the info on the engine tag will be helpful.
They're nice machines, but anything older can be a little temperamental... just ask my wife about me:D
Premium Member
I don't know what kind of boat you traded for it but I think it was worth it. There are always little bugs that you will have to work out when getting a new tractor that hasn't been running for a little while. Plus you got the snow blower which is a plus as they are usually not easy to find. Once you get the serial number and a few more details on the engine everyone will be able to help ya get it going.
Btw, welcome to GTtalk :D
  • Like
Reactions: Dad of 6
Discussion Starter · #6 ·
i put a new battery in it i had the starter tested and it was bad so i put a brand new starter and the wife came unglued when she found out how much it was and i put a new spark plug in it and all the grounds seam fine the numbers on the motor r HH 120-12045E ser-5339E i know the first set is the motor but i cant seam to find what the other numbers mean and a big thanks for all the help everyone has given me allready again thank you very much ill get some pics soon
There is a good chance the SSI is bad, it's a common problem on the old motors.
The bad part is that they no longer make a replacement SSI. Used SSI's on ebay are pricey.
Ed Stoler has directions on a conversion to standard ignition parts, also not cheap, but then everything is easy to replace.
Good luck.
Tecumseh Solid State Ignitions Replacement
Don't give up yet. The SSI is a good candidate, but you may be dealing with something else too. It'll take a few minutes, but it's probably time to investigate a little deeper. verify the magnets are clean, the gaps are right & all the connections in there are OK. Something as simple as a bad ground or lack of one in this system, will make for some pretty big migraines.
Also check to ensure any safety switches are not causing the problem. I recently bought a Ford 120. The guy said the starter was bad. I got home and put power direct to the stater and she spun. Started checking things out and found that the neutral safety switch was bad. I temporarily bypassed the switch and the starter works fine, I have spark and she started right up. My other recent No Spark problem was on an old Clinton motor. I checked everything out and found my points were not making a conductive path to ground when closed. A few small strokes of a very small file, and I have spark.
Take your time working through the problem. Stinks replacing expensive parts to find out it was a simple fix. I know because I happen to be a master at jumping the gun, and finding out it just cost lots to fix a few cent problem.
Ron Paul
Im pretty sure there arent any starter switches.
Take off the fan shroud. Then you will see a silver box above the flywheel. Disconnect the wire from the silver box, the Solid State Ignition module. Then see if there is spark.
Discussion Starter · #11 ·
ok this is messed up my son asked if he could mess with the tractor i told him ya why not u cant mess it up any more so i tried the ssi wire thing and there was spark with and without the wire connected but i asked my son what he did to the tractor he asked me am i in trouble i told him no ur not he told me he didnt remember he was just messen with stuff and the thing is hes 10 but any way he got a lil spark to the tractor so where do i or my son go from here
Ron Paul
That would make sense. Good thing he didnt connect that wire from the SSI to the pos side of the battery $$$
Did you take the carb apart yet? A repair kit costs about $20 and shipping. mower4u.com they take credit card
Ron Paul
The switch could have a bad connection internally or its hooked up to the ground on the back of the switch which would connect it to nothing. Just ask your son what he did LOL
The tractor shuts off by applying the ground to that SSI. I would recommend disconnecting it from anything for now, till you get it running. When you get it running you can connect that wire to a switch. Connect the other wire on the other side of that new switch to the frame. That will shut the tractor off.
Discussion Starter · #16 ·
i asked gage again today what he did and he told me he doesnt remember im about ready to give up on this tractor now it will only run with i think its the stator and coil unpluged i know two of the wires go to the regulater but when there hooked up i dont have any spark i have to start it with a rope but i must say atleast it runs kinda rough but makein progress but im NOT GOOD with electrical issues at all
Discussion Starter · #17 ·
and one more thing i called the local massey dealer and they said that i can not get any parts for this motor no coil stator no nothing. what should i do put a different motor in it cause what is the use of a hh120 if i cant get parts for it?
Ron Paul
You sound very impatient. I dont think an old tractor that you picked up non running is for you.
And thats correct. There really arent any new parts for this engine. But, it sounds as if you dont need more than a simple ignition switch since you said the tractor DOES run when it is disconnected?
Is your tractor a hydrastatic with a large lever on the right side or a gear drive in front of the seat? If it is a hydrostatic a different engine is very simple. Go to harbor freight. For $299 you can have 13HP, electric start, better fuel economy, etc. If you have a gear drive well thats a little different story but it can be done.
Discussion Starter · #19 ·
well me being impatient is my own stupidy and frustration i thought this was going to be a fast and easy fix again i was WRONG i should have looked befor i leaped but i WILL say i enjoy spending time with my 3 older kids messing around with this ol mf i looked i guess u can say under the dash board and what a mess of clobed up mess wires not hooked to nothing cut wires just a huge mess ill try to get some pics of it and the hole tractor
1 - 20 of 33 Posts
