1 - 2 of 2 Posts
Sorry for all the interchange questions, but, is it fairly straightforward to switch the hydraulic lift to a Eliminator series that has manual lift? I have 1658 with hydro lift and a 1668 hydro with manual lift I would like to put the hydro lift to. Is there a potential problem with the manual lift not having a port on the pump?
Thanks again
Tim
It should be fairly straight forward. Worst case you may have to use the filter assembly off of the 1658, as if I recall correctly this is what feeds to the lift control valve. Shouldn't be any issues with the pump at all.
I also recommend you download the parts manuals for both models so you can see and compare the differences.
1 - 2 of 2 Posts
