1 - 19 of 19 Posts
Today, I finally got around to installing the Jaeger version of the Deluxe
muffler that was available for the MF10/12. Member Caseguy(Steve) makes these
from scratch, and he does a great job.
Automotive tire Motor vehicle Vehicle Automotive exterior Gas
It fit perfectly, and installation was a breeze.
Unfortunately
I wasn't able to hear it running, because the 2 boxes of muffler
clamps that the Mrs. picked up at Canadian Tire the other day
where both missing the clamp part. :wallbanging: It'll only take a minute or
2, to put one on when I get it.
I didn't want to run it without the inlet being secured properly.
It sure does look great. I can't wait to hear it.
Thanks Steve for the craftsmanship.
Automotive tire Motor vehicle Vehicle Wheel Automotive design
Wheel Tire Motor vehicle Automotive tire Vehicle
Awesome stuff here!
Banned
Sharp machine! If I ever get my hands on a good Massey candidate for a muffler, someone will be getting a message from me!
Ben W.
Very nice Will. Is that a compressor connected to the PTO! I've never seen that done before. Does this mean that that 10 is earning it's keep as a portable air compressor?
Discussion Starter · #14 ·
I found the clamp I was missing, so I was able to finish the
installation.
Wood Gas Metal Auto part Automotive exterior
That clamp holds the muffler inlet on to the pipe nipple, that
you would normally have there, to screw one of those
pepper shaker mufflers on to.
The other 2 mounting points, are slots in a flat bar, and that flat bar
is secured to the engine block, into the existing 3/8" -16 tapped holes.
The flat bar is the black vertical part in this pic.
Automotive tire Motor vehicle Automotive lighting Hood Automotive design
Once I got that clamp on, I fired it up. Man it sounds good.
Sorry, no video of that. The battery in the camera died.
It's much quieter, and has a nice tone to it.
For anyone wanting to upgrade the exhaust on their MF10/12, I highly
recommend this.
One thing I'm going to have to do, is make up a belt guide finger, to keep
the top of the compressor belt from touching the hot muffler.
Wheel Tire Vehicle Automotive tire Motor vehicle
Steve, I'm wondering if the engineering department, at Jaeger Custom, didn't
get the memo from the engineering department at IamSherwood Custom, saying
that a none original compressor would be in the way. :smilewink: :smilewink:
:bigrofl:
I'm pretty sure he didnt... :D
As a side note:
I bet Wendy would say that is possibly the first time in the last decade that Will has had a problem with his belt being loose...
Will, great idea & simple solution to make the "over centering" pulley for the compressor idler!
I have nothing to add to this thread except to say that I'm very glad that you're pleased! The tractor is absolutely gorgeous and the muffler is a nice accent! Thanks for the pics Will!
1 - 19 of 19 Posts
