I started restoring a JBI last spring and have the tractor back to an operating condition. It was not running when I first got it, so I had to change the points and rebuild the card, but it started right up and I was able to drive it off the trailer. I have sense converted the points/condenser system to a solid-state module. The motor runs good, but does smoke some, so I probably will have to pull the engine and rebuild it at some point. I disassembled the entire tractor, down to the frame and had it sand blasted and then repainted it. The tractor is back together now and I have run it to be sure the transmission is working. I did have to replace numerous bearings (front axle, front PTO and starter/generator) but the main drive train is working great. The next goal is to get the front end loader (FEL) working. I have replaced all hydraulic hoses and have tested the hydraulic pump and control valve. So far the FEL seems to work with the exception of the bucket. The original bucket was trashed, so I have removed the mounting brackets and have them temporarelly applied them to a replacement bucket. The last phase will be to rebuild, sand blast and paint the mower deck and bucket. Once I reach this point I will test the overall tractor operation by doing some light dirt work. I do need the lift arms for the 3-point hitch, so it anyone has these for sale, let me know. I have included a few pictures of the progress to date.
