This summer, my 316 started hunting severely. After many years of grass cutting, I decided to do a major rebuild on the entire engine and fix every other little thing that was wrong on the tractor. This engine had been short blocked by the PO, and about a thousand hours on it, but has been properly maintained as long as I've had it. Everything part in this engine was well within spec, and in excellent condition, so I did the rings, cylinder hone, a valve job, and all associated seals and gaskets. It's hunting at wide open throttle, so that leads me to believe that it's not a governor issue. No amount of adjusting of the springs makes any difference. The oil filter cylinder side is already full of carbon, unlike the opposite side which has a normal burn pattern, which leads me to believe that the intake valve is sticking from what I see. (It spits fuel up out of the carburetor on shutdown). The valves spin freely in the block, the oil gallery oils properly, the valve lash is set properly, and I believe this valve is hanging open only when the machine is running. No amount of rotating this engine by hand gives me any indication that anything is wrong. Could this be a week valve spring, or a valve seat that's moving during operation?
An initial bit of information, after the rebuild, on the first startup this machine ran beautifully, and in about 15 minutes it went back to its old hunting ways. My guess is when the assembly lubricant I used finally washed out, that's when it went back to hunting.
Any help on this will be greatly appreciated.
