1 - 12 of 12 Posts
gttalk enthusiast
Does anyone know what size belt or belts "im guessing theres 2" the run the mower deck on a 1967 round fender 110? Or belt part numbers?
And if you could help me also by telling me what size belt that goes from pto to deck on a john deere 210 with a 38 inch deck?
M45998 - tractor to deck belt #25 in attached pic 7610
M40223 - blade to blade #17 in attached pic 622
This is for decks over 3661 serial number too. www.jdparts.com is where I got the info
  • Like
Reactions: superspeedex
gttalk enthusiast
Discussion Starter · #6 ·
Got my belts put the deck on all i can say is wow is that deck quiet dont spin very fast but quiet why is it in the 60s they can have a tractor that quiet but these new mtds are so loud they sound like there flying. Any way my mule drive to deck belt is slipping in deep grass didnt see any adjustment on the spring is there something im missing?
It is possible you don't have enough tension on the belt from the crank to the mule drive. It is very easy to adjust tension. If you need info from the service manual I have it at home.
  • Like
Try adjusting the idler pulley on the mule drive along with the "L" shaped piece that ride against the belt. The "L" shape piece should just lay against the belt, and should not be tight. Apply the mule drive so that there is tension on the belt, and set the "L" shaped piece so that is just touches the belt, then tighten the nut. I'd also check the tension spring that goes between the mule drive and the front axle. These springs wear out and yours might need replacement.
gttalk enthusiast
Discussion Starter · #10 ·
How do i check if it needs replaced?? thought about just addding another spring
Do your adjustments to the mule drive belt first, then run the mower to see how it performs. If the belt still slips, then I'd replace the tension spring. I forgot to mention, the idler pulley on the mule drive should be keeping the belt tight when the pto is activated. When not activated, the mule drive belt should not be turning. Check to make sure your tension is set correctly for the idler pulley, since you said your mower deck blades still turn when the pto isn't activated.
This would be so much easier to explain in person. :( Just where is Kittanning located in PA anyway? We should just meet some Saturday, and then I could show you all the in's and out's of these old round fenders.
1 - 12 of 12 Posts
