1 - 2 of 2 Posts
hello folks, i figure before i get help for the day and get into another project id make sure its feasible first. i have an ht20 with a johnson 14 loader on it with a pto driven pump. i was wondering if a cozy cab will fit on the tractor with the loader on and still be all operable. also the ht20 has the hand control hydro lever on the left that goes forward and back with the right foot pedal. i figure between the cab, loader and a weight box it would be a pretty neat looking thing to put together. and the cab would help with counter weight a little.
You can put a Cozy Cab on a LF tractor with the Johnson loader on it. The change you might need to make will be the infill sheet metal pieces on the leading part of the cab. Note that those are only held on with a few bolts and are therefore removable. Then you could fabricate new sheet metal panels to fit between the cab and the tractor while clearing the loader and the hand control.
  • Like
Reactions: boyscout862
1 - 2 of 2 Posts
