Can anyone answer me on this one please? I have the old style block with the 1-1/8" exhaust valve. I was wondering if it was possible to cut out the old seat and insert the new 1-3/8" one and put in the new valve?
There are bronze bushings that people use on the throttle shaft. Drill out the body of the carb and press in the insert. I will see if I can find it.SO,,, that brings up a question..??? How can I re-size my throttle shaft openning... is there a sleeve.?? My throttle shaft warbles at the intake and causes the throttle shaft to bounce around.......??
I have the Zenith carb. I beleive it's a ,, model 1408There are bronze bushings that people use on the throttle shaft. Drill out the body of the carb and press in the insert. I will see if I can find it.
I have been looking and not having that much luck. I wish I could find one. Does anyone have any suggestions? I would really like it to be an inline twin and around 18 hp to 30 hp and not a budget killer. Would like to keep it at 3600 RPM, too. On a side note, I do have a Wisconsin THD that is sitting around that could go in there, but it is in pretty sad shape.Isn't there a two cyl. engine available that would save you having to reinvent this whole thing? I've seen a puller w/ a Suzuki Hayabusa engine that was killer.
I would go with the THD. The money you spend on the homebuilt would rebuild the Wisc. I'm not trying to be a kill joy, but I'm afraid after you get the dual Kohler together, you will spend a lot of time trying to get it to run right. Now, if you were to belt two engines inline, that might be doable.I have been looking and not having that much luck. I wish I could find one. Does anyone have any suggestions? I would really like it to be an inline twin and around 18 hp to 30 hp and not a budget killer. Would like to keep it at 3600 RPM, too. On a side note, I do have a Wisconsin THD that is sitting around that could go in there, but it is in pretty sad shape.
