1st make sure the head bolts are torqued to 30-35ft lbs Head torque does affect Valve clearances on these.
2nd Both valves get adjusted to .005 or .013mm Cold K361 has adjustable tappets on the rocker arms.This is unique to the K361.
3rd Points to .020
Many people dislike the K361 because the Valve seats are known to drop out of the head.This happens if the cooling fins on the head become clogged up or the engine runs Lean for any amount of time and overheats.
