K-241
HP: | 10 |
Cylinders: | 1 Cyl |
Block Material: | Cast Iron |
Cooling: | Air Cooled |
Compression: | 5:1, 5.4:1 or 7.1:1 (See Foot Note) |
Points Gap: | .020 |
Max RPM: | 3600 |
Bore: | 3.251 |
Stroke: | 2.875 |
Displacement: | |
Spark Plug: | CHAMPION RH-10 |
Plug Gap / Battery: | N/A |
Plug Gap / Magneto: | N/A |
Int. Valve Clear. Min: | .008 |
Int. Valve Clear. Max: | .010 |
Exh. Valve Clear. Min.: | .017 |
Exh. Valve Clear. Max: | .019 |
Oil Type: | SAE30 |
Oil Capacity: | 2 Quarts |
Fuel Type: | Gas |
Footnotes: | Compression is dependent on which cylinder head was used. |
Related pages: | 66TME-10, Chief 1000, IH Cub Cadet 102 |
