1 - 1 of 1 Posts
· Premium Member
K-331
HP:12.5
Cylinders:1 Cyl
Block Material:Cast Iron
Cooling:Air Cooled
Compression:
Points Gap:.020
Max RPM:3600
Bore:3.625
Stroke:3.25
Displacement:33.6
Spark Plug:CHAMPION RJ-8C
Plug Gap / Battery:N/A
Plug Gap / Magneto:N/A
Int. Valve Clear. Min:.008
Int. Valve Clear. Max:N/A
Exh. Valve Clear. Min.:.020
Exh. Valve Clear. Max:N/A
Oil Type:SAE30
Oil Capacity:3 Quarts
Fuel Type:Gas
Footnotes:Kohler rated this engine at different HPs at different RPMs. 8.2 HP at 1,800RPM, 10.2 HP at 2,400RPM, 12.3 HP at 3,000RPM, 12.5 HP at 3,600RPM. The engine also used an pressurized lube system with an oil pump and filter. Had as standard feature, over heat automatic kill swithc.
Related pages:
1 - 1 of 1 Posts
