1 - 4 of 4 Posts
Got Sum
There has been discussion here several times about replacement coils for these engines. The ridiculous price of the new Kohler ones ,Harley ones, etc. Most if not all are Chinese. I'm not a proponent of used electrical parts especially if the engine is exhibiting electrical woes. I've switched to these ,made in USA and IMO reasonably priced to what's out there.
.. there is that horrific yellow color resembling team green, Krylon aerosol for plastic in black has addressed any issue the Bolens may have with "spitting out the bit" at the sight of the yellow
http://kirkengines.com/index.php#DualSuperCoil
A Little Off Plumb
I have found that if you turn the lights down low and just use a flashlight you can sneak a different coloured part onto a Bolens and it will not complain too loudly. Just promise that you will love it faithfully even though it is not in the same condition as it was when you first met it and all will be good.
I think I read somewhere that the stock Kohler coil for the K-series twins had a primary resistance of 5 ohms. The yellow ones Kirk is selling have a resistance of 6.1 ohms. Does that make a difference?
Got Sum
He says no in the description , I'm running them on 3 K series twins with no problems , points are fine.
1 - 4 of 4 Posts
