LGT 165 Kohler K301 Throttle Spring Not Tight
349 Views 6 Replies 5 Participants Last post by  DG65
After rebuilding the engine, the throttle lever and cable has no effect on the governor spring. Moving the lever does not move the throttle. I read about adjusting the governor arm, but that does not tighten the spring. I don't know if it is hooked up correctly as the nut on the breather gets in the way.
See less See more
  • Like
Reactions: 1
1 - 7 of 7 Posts
Can you post a larger picture please?
  • Like
Reactions: 1
Looks to be correct. All of my Kohler engines use the older style linkages but yours does look to be set up correctly.
Is it possible that the stud on the breather backed out a bit? Did you have it apart?
  • Like
Reactions: 4
Seems right. What you have there. Is the throttle wide open or closed in those pictures. I’ll post two pictures off my John Deere. K321 engine.
First picture is wide open. Other picture at idle.
Two more pictures. Case 224 tractor. K321 engine. First picture at idle. Second picture wide open throttle.
Noel
See less See more
4
  • Like
Reactions: 5
With the engine off the governor will always pull the throttle wide open and the spring will be loose. You likely do not have the governor shaft set right.
Please tell us how you set the governor.
  • Like
Reactions: 2
I had same problem ended up being cable/linkage adjustment. I have a little different throttle linkage but maybe yours is not correct.
  • Like
Reactions: 1
1 - 7 of 7 Posts
