1 - 4 of 4 Posts
Hi
Bought a lift lever as my tractor was missing one - could someone glance over my pictures and tell me what isn't attached correctly/wrong place. I suspect the bar down the bottom should attach to the tractor somewhere for the lever to rotate around.
Thanks
Bob's Lawn and Garden LLC
From the pic that bolt with the nut on it is where it goes. Remove the nut and you will see the lift lever I sent you has a threaded hole that is where the bolt treads on to it then the nut with a lock washer goes back on.
Deceased
That plate mounts using the bolt. The stud above the bolt is used for front mounted attachments and the one at the bottom for rear mounted attachments.
Here are two pics that show how it should look. Ignore the fact that it doesn't have the lever as that gets removed when you use the hydro lift attachment for the tube frames.
1 - 4 of 4 Posts
