1 - 11 of 11 Posts
Picked this up yesterday:
Wheel Tire Vehicle Automotive tire Motor vehicle
Wheel Tire Vehicle Automotive tire Hood
My 15+ year old 550 Mule ready for replacement, I've watched for a used 610 Mule for months with no luck, they all want nearly new price! I found a pair of used Gators about 90 miles from home. Went to check on them yesterday and came back with this '06 TS, all new tires, an after-market canopy, 1270 hours ( more than I prefered, but acceptable). No breaks in the plastic, seats are shot (new ones on order), some minor dings in the bed, but nothing too bad, belly pan doesn't even have the paint worn off! I'll be doing some work on it to suit my needs as time allows.
Now to get the Mule ready to sell! ~~ Lowell
Freedom is not Free. Thank those in uniform for yo
Looks like you got what you needed and that is good. Hope it works out for ya.
Discussion Starter · #4 ·
Kooool!!! Do you play golf? Or do you just ride it around the retirement home?
No retirement home -------------------------- yet!
This is what's in store for the Gator when the time comes:
Tire Wheel Sky Plant Vehicle
Lowell
Discussion Starter · #6 ·
Better put in a bench seat so both the dals. can ride, lol.
That's the main reason I bought the Mule over a Gator the first time! ~~ Lowell
  • Like
Reactions: oldedeeres
Discussion Starter · #7 ·
New high-back seats are on!
Wheel Tire Plant Vehicle Car
I used 1-1/2" thinwall square tubing to make the new rear canopy frame, "flattened" expanded metal for the screen, which holds SMV, machete & steeple pullers.
Green Plant Motor vehicle Bumper Automotive exterior
A rack on the back frame now holds two receiver drawbars.
Green Gas Engineering Machine Auto part
Frames for 8" sideboards are made, will finish with 1/2" AC plywood. ~~ Lowell
Discussion Starter · #8 ·
Brush guard is finished, along with (ammo) tool box mount:
Tire Wheel Vehicle Car Grille
Green Plant Grass Gas Machine
Wheel Tire Vehicle Plant Automotive tire
I have most of the parts for the electric lift now, just need time to install!
Also still need to wire the winch hookups. ~~ Lowell
  • Like
Reactions: Alc
enjoyin the livin part of life!
Nice gator! Looks like you're getting it outfitted quite nicely. Knowing your cart collection will you be setting up a green trailer for it to pull?
That looks good, Lowell!
  • Like
Reactions: grnspot110
Discussion Starter · #11 ·
Hopefully I can find a #21 cart some time, or even a Gator bed to make one. Not that I really need one, but! :D ~~ Lowell
1 - 11 of 11 Posts
