1 - 11 of 11 Posts
I just finished adapting a 50" JD deck to my MF 14. The original deck needs some major work done to it. To be able to mow I mounted a JD deck from a 318, with a little welding on JD mule drive and using the same lift mount, it mounted on pretty easy and was able to use the same drive belt. Motor vehicle Automotive exterior Automotive tire Gas Automotive wheel system
Welcome to the site esbbent! It looks like you used your noodle to keep the Massey mowing! Good job.
Premium Member
Nice job on the deck rework. Also welcome to GTtalk. :D
Premium Member
Looks like you'll have a good cutting machine.BTW looking at the one pic that shows the discharge side,it almost looks like the blade is on upside down.Not sure about that as pics can sometimes not show everything.Also welcome to GTTalk.Larry
Welcome to GTTalk esbbent!
Love to see people that can think outside the box.
Please take a look at our Member map and feel free to include your location.
what did you do with the old deck ,does it have any good parts on it ,I need the whole center spindle assembly the one that the mule drive hooks to and runs the deck belts
good job on the conversion there is alot of jd decks out there when you compare it to the masseys we have available
good job thinking outside the box
Welcome esbbent. Glad you are here. Nice deck work.
Discussion Starter · #8 ·
thanks for all the replys
thecoater I still have the massey deck and am planning on fixing it up. It needs some welding to fix a hole along with finding the center spindle.
masseydriver-thanks for the heads up I need to take all the blades off and sharpen them and make sure they are put on the correct way.
I have to ask LOL ,,what is the difference in the jd spindle and the massey
could I just switch this out with an assembly from another deck and just use my pulleys on it?
Discussion Starter · #10 ·
the coater-the jd spindle looked like it would work except the lowere pulley sits about 2" too low to match up with the Massey outer spindles. :wallbanging:
Discussion Starter · #11 ·
Due to colder weather and a few more weeks I decided to repaint this John Deere deck. I did compare the Main Drive spindle from the 318 deck to the Massey deck to see if it would be a fit. 2 things;1 the bolt holes would work, the 3 for the JD match with 3 of the 6 on the MF deck. 2 the top pulley would work but the bottom pulley on the JD spindle sits down 1 lower than the MF pulleys. Here are pictures after repainted, couldnt help repainting the mule drive MF silver :D
Tire Wheel Automotive tire Hood Grille
1 - 11 of 11 Posts
