1 - 18 of 18 Posts
I went on a 200 mi road trip last night and came home with this 1200.I bought it on ebay.It came w/snow plow,mower deck,4 hub caps and rear mount weight box which is a massey weight boxthat is full of steel scrap so it's got some weight to it.I didn't know the weight boxes existed.I couldn't find any pictures of them in my brochures that I have.I couldn't view the agco parts books today either.I'll try again tommolrrow.It runs great but needs a battery.I found out tonight that with the weight box on back I need to be careful w/the clutch,the froint end comes off the ground about 6". :D The led strobe lights will be coming off the back.
Tire Wheel Automotive tire Vehicle Tread Wheel Tire Car Vehicle Automotive tire Wheel Tire Vehicle Automotive tire Hood Wheel Tire Vehicle Motor vehicle Automotive tire Tire Wheel Vehicle Automotive tire Motor vehicle Wheel Tire Plant Vehicle Automotive tire Wheel Tire Automotive tire Plant Motor vehicle Tire Wheel Vehicle Motor vehicle Automotive tire Wheel Tire Vehicle Motor vehicle Automotive tire Motor vehicle Automotive tire Tire Wheel Wood
Very nice haul, a lot of original equipment too. Congrats!
  • Like
Reactions: ckjakline
Discussion Starter · #9 ·
Last night I cleaned up the hubcaps.I got most of the rust off.The one front hubcap really cleaned up nice.The other front half of it cleaned up nice the other half the chrome was already flaked off.The one rear hubcap cleaned up ok.the other looks better than it did anyway.Here are the before and after pictures.
Road surface Asphalt Font Circle Automotive wheel system World Ball Circle Font Art Dishware Tableware Serveware Gas Font Dishware Automotive tire Tableware Asphalt Road surface Road surface Asphalt Circle Concrete Font Hood Automotive lighting World Tints and shades Circle Road surface Asphalt Circle Art Concrete Handwriting Ball Road surface Asphalt Gas
I have a friend who collects Wheel Horse GTs and loves to find the hubcaps. He has someone beat them out (yours don't look like they need it) then has them re-chromed. His are all show tractors.
She is in awfully nice condition for sure! I looked at the MF1200 through 1855 on Agcoparts, and found no listing for the weight box.....maybe a nice custom build?
Discussion Starter · #14 ·
It's possible it's custom,but on the other hand it's to perfect of a fit to be custom.So I'm not sure.I'm definitely going to research it.
Good looking machine. Congrats.
I've never seen one in person. So, it has a 12hp Kohler? And it's a gear drive
tranny, with a drive shaft from the Kohler?
Deck lift lever on right side? Is it the same physical size as a 1450?
Discussion Starter · #16 ·
It has the k301 12 h.p. kohler.Yes it is gear drive.Driveshaft goes from the flywheel to a gearbox.The gearbox has a pully coming off the side parrellel to the wheels.A belt goes from the pully to the transaxle.The output shaft off that gearbox feeds the rear pto for you 541 pto unit,rototiller and I believe they had a pull behind brush hog type mower that run off that shaft.I think it is the same platform as the 1450,but not positive.Yes that is the deck lever on right side.
Discussion Starter · #17 ·
I picked up a parts manual for this tractor and was paging through the attachments part of the book and seen they had 2 different lawn sweepers avail for this tractor.I didn't realize massey had lawn sweepers.Now I have something else to look for.Has anyone seen any of these or does anyone have one?
I've came across one. The fellow I bought my blower had one for sale as well. But I had to pass on it and the front blade. Haven't seen one since and that was 5 years ago now. I'd really like to find one too. Good luck.
1 - 18 of 18 Posts
