1 - 14 of 14 Posts
Hey Guys
I was out playing in the snow today with my MF16 and ran into a couple issues that I wanted to run past you. The snow was pretty heavy yesterday but I have never had an issue with it before, until now..
From what I can tell (without fully dissassembling it yet) the teeth on the "jack shaft" have been rounded off and the drum freewheels (with minimal resistance). It looks like this is a welded shaft with the sprocket on one end...has anyone else ever run into this? I was hoping it was a shear pin or key or something....
Any help would be appreciated.
Thanks
Steve
You could probably cut off the existing sprocket and get a new one welded back on. If it's like the JD I have, the factory shaft and sprocket assembly is really expensive if it's still available. You could also get a piece of shafting and a sprocket and make up the entire assembly. I'm not sure on parts availability for the MF attachments.
Will, I think the sprocket on the other end of the jackshaft may be worn out. The key could also be broken which would be a cheap fix provided nothing else is ruined.
Well this is weird but I ran into the same problem today. I removed the jackshaft assy and the sprocket at the end has been totally rounded off, no teeth left at all. I was hoping that anyone here might know where I could get another shaft. I have looked everywhere online today with no success. The snow thrower is the MF 520
Discussion Starter · #6 ·
Okay...I think I have a resolution.
"iamsherwood" yes its item #1
"thglider" did your sproket look like the pictures attached (sorry for the mispelling)?
I was pleasantly suprised to find that the entire jackshaft assy can be removed from the blower in about 10min. I was expecting it to be much more of a project. Anyway, as you can see in the pics, the sproket (or so it was..) is welded to the end of the solid 3/4 shaft. As far as I can tell, this is, or was, a 13 tooth sproket #40 chain (if someone has another count please share). I located a 1/2 bore 13t #40 from Amazon (shown in pic). I plan to remove the old sproket from the original shaft by grinding the weld and tapping the sproket off the end. Next, I will turn the end of the shaft down to accept the 1/2" bore sproket. By turning this down, I hope to ensure that it will be true and centered when rewelded. I am thinking this will take care of it for another 30 years or so..ha ha...what do ya guys think?? Amozon Parts.jpg Shaft w welded sprocket.jpg Sprocket.jpg Welded End.jpg
Your plan should work perfectly. It would appear the OE sprocket was the "sandwiched" type sprocket, which don't hold up as well as a solid cast sprocket in most cases. The replacement should last a long long time. The biggest enemy of sprockets though is a worn out chain. Be sure to get a new high quality chain, or the sprocket will suffer an early end. An O-ring chain is the best, as they have small o-rings that hold the chain's internal lube in, and they last 4 times or more longer than std roller chain.
What a mess that "sprocket" is. Surprising it was still doing anything.
Well, at least you don't have to deal with a buggered up keyway.
Thanks for the info on the O ring chain Daniel. I had no idea.
Dang! that is some serious sprocket wear for sure! Your idea will work perfect, but I would sure look at all of the sprockets on that chain drive, I would think you have little luck the rest are ok.
O-ring chains is the only way to go with motorcycles/ATV's....except for driveshaft which is way better. They make special lube for o-ring chains that goes on like penetrating fluid, really thin to get past the o-rings, then it thickens. I bought my 1st can of it 35yrs ago and thought I got a bad can of chain lube. Thinking it was bad anyway, I sprayed it all over the chain to at least do something. A few minutes later my hands were sticky as glue! THEN i read the can! :hitting_self_roller: For a snowblower in the wet environment, the o-ring chain is the way to go,.
I'm afraid to look at the chain and sprockets on the 49 thrower I bought. It may be in the same condition.
From the other site.
Here's the link you gave me. The large sprocket and clutch plates on Patton Acres have been on there ever since I saw them a year or more ago. It's not a great price, but also not terribly bad for NOS considering the sprocket size and rarity of finding them new.
Personally, I gave up on hunting for "Massey" parts. I found that same tiller was used for 3 or 4 different brands, including the JD 33 tiller. That's how I landed on an eBay ad for all the sprockets, hubs, clutch plates, etc. that I needed. Somebody tore apart their 33 and it's a direct fit to our tiller. I was pretty psyched to get all that!
If whoever is asking needs measurements or tooth counts, I can help out easy enough. I have the stuff still in the box on the shelf. What forum is that on? GTTalk? I'm on a few different ones but I only really use this one.
http://unclehenrys.com
http://pattonacres.com/cart/massey-f...s-c-18_45.html
Tractorfanatics.com
Another good source for for sprocket and hub are the make your own from TSC or Fleet farm. Many implement dealer also carry the make your own one.
1 - 14 of 14 Posts
