1 - 7 of 7 Posts
Hello. I have a massey 1650, bought it used, and sight unseen (normally dont do this, but was willing to wager on it).
It works great, EXCEPT the forward/reverse foot pedal is very loose, and it does not stop very well.
there is no central / neutral stop - i kinda have to find the sweet spot, then pop it in and out of gear (sometimes with grinding gears)
should the pedal normally return to the centre / neutral position (not forward or reverse). is there a relatively easy way to diagnose / fix this? i dont want to damage it.
Unfortunately, this is my first hydrostatic tractor, and im not sure what it is supposed to do.
I bought it because it has a front end loader (homemade) and i had a lot of landscaping to do. that was last year. i did my landscaping, and am done with working the tractor, but i would now like to restore it, maybe..
thanks for any help
Hi there, fellow Ontario'an.
Welcome to GTT. :wave:
Quick answer to your ? is yes, it should return to neutral.
First thing I would do, is remove the plastic tunnel cover, and the 2
side panels. Spray all the linkage points with Fluid Film/WD40, or whatever
you like. Or it could be a broken return spring, which will be visible.
Maybe if you post some pictures, we can spot something.
Here is a good site, just in case you're not aware of it.
agcopartsbooks. com
Sign in as a guest.
Also, there are manuals available for free here after you've a certain
number of posts.
Hopefully this helps you some, but ask away if you have more ??s
Lots of knowledgeable folks here.
Welcome to GTTalk. Congrats on the new tractor. It sounds like you should be able to get that hydro control problem sorted out.
"Grinding Gears"?? This when going into the range with lever on fender?? Other than that, should be NO gear noises. All hydros have N in middle and should go to N when you step on a Brake pedal also. Some have brake on other side, others kind of above the hydro pedal, I forget which you had. Many hydros of all brands have this N problem over time and need re-adjusting. Best you get the manual, or I see some have links here now, and study and try that.
Likely just a broken return spring. Grinding when putting into hi or low range is only because the foot pedal isn't sitting on the neutral position.
1 - 7 of 7 Posts
