1 - 20 of 41 Posts
Premium Member
My electric PTO on the Massey MF1655 decided to let loose again. Another rivet on one of the fingers broke. I found some electric PTOs on ebay that I think may work since they are for a JD 318 which also has the Onan in it. Not sure what the part number is or if one would be available for the Massey. Would like to just get a new one and fix it and be done with it.
  • Like
Reactions: propane1
A 318 clutch won't work as the JD's use a much larger crankshaft output shaft.
Is that on an 1-7/16" shaft?
  • Like
Reactions: NUTNDUN
Just imagine what an 1-7/16" PTO would cost new!
  • Like
Reactions: NUTNDUN
George, if you never plan to use a mower deck, then all this runs is the hydraulic pump? If so, then just put a normal pulley on the engine to run the hydraulics. That's how I have my 1655D set up. Even before I took the Onan out & replaced with the diesel, the drag of the pump didn't affect starting at all....even in cold weather.
Premium Member
Discussion Starter · #10 ·
What pulley setup did you use? I doubt I would run the mower deck off of it. Too much of a pain to remove the loader even though I could leave it on if I were to do the mower deck.
Reason I mentioned the John Deere was I came across some of these electric PTOs on ebay: http://www.ebay.com/itm/251525499019
George do you have any pics of a pto for the Massey I may have some off of Sears tractors hanging around as the Deere's got some of them too would think you could have a sleeve made to make them fit if the pulley sizes are correct
Premium Member
Discussion Starter · #12 ·
I can get some pictures tomorrow. There is bound to be something else that would work. I could also do like Daniel suggested and do a straight up pulley as I doubt I will ever use the mower deck with it.
I cured the problem of no elec. clutches available for 1855s/Onans. No kids or much in animals around my place, so I used my MIG welder. Now it runs all the time but is a pain in the backside to start with the snow blower on.
I could have sworn my 1855 had a 1 & 7/16 clutch on the front, maybe I am wrong- always a first time :dancingbanana: . I do remember one other brand though that used a very simliar if not the same electric PTO assembly.
I have looked at mine and tried to figure out how to make it mechanical with a lever and idler pulley.
I could be wrong on the crank size....wouldn't be the first time!
Most of the Onan's are 1-7/16" shaft. Makes it hard to find anything to fit them!
  • Like
Reactions: NUTNDUN
The JD 318 is definitely 1 & 7/16", so if the Massey's Onan is the same, then a 318 clutch will fit. I measured the Onan I did have in my 1655, but that Onan came out of a 318 Deere. I got the 1655 without an engine.
Likely doesn't matter now that Bob has put out an offer George can't likely refuse! :thumbs:
1 - 20 of 41 Posts
