1 - 20 of 35 Posts
Premium Member
I am sure some of you guys have repaired the hydraulic lift cylinders on one thing or another. The right bucket tilt cylinder on the newly acquired Massey 1655 is leaking. It must be the bottom bore seal and slowly follows the path of the cylinder and drips on the floor. It isn't the fittings. Will I be able to get the parts I need to rebuild the cylinder myself or should I take it to a hydraulic shop and let them do it?
Premium Member
The inside of the cylinders aren't that hard to do yourself.Basically it's a o-ring and a wiper ring you really just need to change the 0-rings and you'll be good to go.The hardest part sometimes is taking the cylinder end caps.You'll have no problems doing one yourself George.Larry
  • Like
Reactions: NUTNDUN
Larry is right, you can do it yourself. Only thing you need the hydraulic shop for is getting the proper o-rings & wipers. Usually the o-ring kit boxes aren't the right o-rings, as all I've ever seen in these hydraulic cylinders & valves are a thicker o-ring.
Premium Member
Discussion Starter · #4 ·
Thanks guys. Once I get the 20hp Onan in place and wired up I will see about pulling that cylinder off and taking it apart. Good thing is the hydraulic shop is right beside my work so I can swing over there on my lunch break one day through the week.
Premium Member
Discussion Starter · #5 ·
I gotta do some work on the loader, I am hoping it is just that it needs oil but haven't checked that yet, been too busy with the engine swap. I had to get the mower deck that came with the new 1655 off of the trailer so I could load the Snapper 1655 and take it to the new owner today. I got the deck hooked up to the bucket and it wouldn't even pick it up, it actually dropped. I ended up putting as much tension as I could on it and then just slowly drug it to around back of the garage. I am hoping it is just low fluid but there is a chance that the control valve is shot. I found a 4 way loader valve on Northern tool and it is around $200. Even if the valve isn't bad I see the 4 way in my near future. I want to redo some of the hydraulic hoses also.
Sometimes removing the gland nut is tricking threaded on or snap rings, sometimes they use a small square locking key ( hard for me to explain ! ) That's great that you have a place to pick up parts . They should be able to match everything up for you.
  • Like
Reactions: NUTNDUN
Premium Member
Discussion Starter · #7 ·
I just went out to the garage because curiosity was getting the better of me. I wanted to check the oil level to make sure that wasn't the problem. I pulled the breather off and added about a quart of oil. Not nearly low enough to cause problems. So I fired it up and I showed dad how if you just barely move the lever on the lift valve the arms actually move the opposite direction until you move the lever more and then it moves in the direction it is supposed to. I think it is definitely the control valve that is shot. I stood in the bucket and had dad move the lever and it wouldn't pick me up, not that I am a lightweight but I would think it should lift me up, I am probably around 230 lbs.
George, it should lift you like you're not even there!
Premium Member
Discussion Starter · #9 ·
It goes down, down, down almost like you move the lever the wrong way. It is either the pressure relief or the valve. The bucket tilt works good though, that is actually how I got the mower deck lifted enough to drag it.
Could it be sucking air somewhere?
Usually through the carb.
Premium Member
Discussion Starter · #12 ·
I took a bunch of pictures of the hydraulics for the loader as well as the cylinder seals. The one that is leaking looks like they replaced the original seal with a rear end axle seal. I also took a video of the loader to try and show what it is doing with the various valve movement. Will get it uploaded and posted then.
I also took a pic of the 20hp Onan Performer in it's new home. The thing has never run better :D
Here are the pics:
The valve's lever link plates aren't worn....those are link plates from roller chain.
Premium Member
Discussion Starter · #14 ·
I know the lever plates are not right, if the valve was good I was going to make something better that didn't have as much play. They wouldn't have anything to do though with how it is acting.
Oh no, just pointing out what the plates were. Never heard of a valve doing what yours is. I just wonder if the slight push going up is normal up, and all the way is a float position? Either way, something isn't right. But the pump must be fine considering the tilt is strong.
Premium Member
Discussion Starter · #16 ·
I didn't mean to come off rude, after I hit the submit button I reread what I typed and I thought it sounded snottish and I didn't mean it that way :D
There were quite a few things that have been rigged, I am slowly making progress at getting things the way they should be. I got the video uploaded showing how it is acting, the shop is a mess and I have tools laying everywhere. Anytime in the video that the bucket moves I am pulling the lever back, when it does go up it is when I pull the lever back all the way. I did put it down a little at one part of the video to keep everything in focus.
I didn't take it the wrong way George! Besides, by this time of night, I do good to type right, much less express feelings correctly! LOL Nope, after watching video, nothing to do with any float position. As fast as it does raise "no load", I'm surprised it has no lift capacity.
Premium Member
Discussion Starter · #18 ·
I talked to Al on the phone earlier tonight and he had a good idea, since the bucket tilts just fine and has power with that, swap the four lines on the valves and see if the main lift is any better, if it is good then I can rule out anything else and replace the control valve. I looked at the control valve while I was taking pics and it would be pretty quick and easy to swap the four lines since they are all the same fittings. A lot of the ones I have seen usually they will have male on one and female on the other as not to get them mixed up.
Now why didn't I think of that! I do the same type thing with spark plug wires & coils to see if problems follow the switched parts.
Premium Member
Discussion Starter · #20 ·
I am really hoping it is the valve, then it gives me an excuse to get the 4 way loader valve :D
1 - 20 of 35 Posts
