1 - 20 of 25 Posts
I think the tank I have is the same as yours, Alan. But the bracket is way off.
Motor vehicle Wood Gas Font Machine
Wood Motor vehicle Bumper Brick Automotive exterior
Wood Gas Motor vehicle Tree Font
Motor vehicle Wood Tire Automotive tire Wheel
Automotive lighting Motor vehicle Wood Automotive exterior Gas
Brown Gas Wood Metal Composite material
Folks,
I can't tell you if they are unique, tank or bracket? I don't have a correct tractor to look at! So looking for pictures too.
Maybe this should have been in the wanted section?
Regards,
Chris
Start a post there and put a link to this thread!
Discussion Starter · #7 ·
esbbent, on 22 Nov 2015 - 1:42 PM, said:snapback.png
Here are a couple of pictures of the MF8 gas tank and the bracket that holds the tank. The tank sits down in from the top and clamps around the tank just below the lip that goes around the side of the gas tank.
Folks,
I found some pictures of the bracket and tank these were posted on here a while ago and I forgot about them. Thanks to esbbent!
The bracket is unique and wraps around the tank spring loaded. I cant see the other side of the bracket so not sure how it attached to the engine? Also not the steel tank with the very short neck. I assume this helps keep it under the hood?
Regards,
Chris
What engine does this MF8 have?
Discussion Starter · #9 ·
Kenny,
You know, that is a excellent question! And currently I don't know the answer. I can't find any data tags. It is a Tecumseh engine. It seems to be the right fit for the tractor. The air cleaner coming out the left side of the grill seems to match other Massey 8 tractor pictures I have seen. I have been assuming its a 8 hp? Not sure if the experts on here can tell? Some pictures.
Regards,
Chris
Discussion Starter · #15 ·
Folks,
I need a kick to get going on this lawn tractor again!
I did find the engine number:
HHM80190005 ser 23220
In talking with Bob (sponsor, and very helpful) he thinks that this is a replacement engine.
So I may have a non original engine. The tank support and tank may be more of a challenge too.
Regards,
Chris
Discussion Starter · #17 ·
Sugarmaker, I sent you a pm but not sure if you received it. I was chatting with a guy in Indiana today and asked if he had a gas tank for your 8. He said he did and for you to give him a call. His name is Rick and his number is 7six5-938-nine510.
Thanks!
I did talk to Rick and he is checking on some parts for me! Appreciate the information. May help me get going on this little Massey project.
Regards,
Chris
Good to hear!
He hooked me up with some very hard to find parts so I was hoping he would be able to help you also.
I feel that this is the funniest part of getting a old pile of steel going again...the thrill of the hunt and then actually finding what you need!!
Discussion Starter · #19 ·
Good to hear!
pappyMF,
Yes I like the hunt for parts also. This Massey is a little different for me since I really dont know much about these tractors. So learning a lot.
Regards,
Chris
If you need any pictures of how anything should go or be mounted, I'm pretty sure my son's "new" 8 is all original.
Here it is with most of the sheet metal removed. Should be back from the paint shop around the middle of next week. Our buddy Rick hooked me up with an original muffler assembly that should arrive shortly also.
We are trying to get it ready for the Lebanon Valley Indoor Tractor Show in Mid February. Wheel Tire Vehicle Automotive tire Motor vehicle
1 - 20 of 25 Posts
