1 - 5 of 5 Posts
Premium Member
I am not really sure what is causing the problems but if it is cooled off it starts right up and runs great and as long as you don't shut it off it runs great when it is warm. Although it dues start to fluctuate / surge on the idle but full throttle runs great. If you shut it down after it is warmed up you can forget about starting it.
I have to walk away from it and let it cool off before I try and start it again, and it needs to cool off a lot, even sitting there for 15 minutes isn't enough.
I don't think it is the carb because that has been cleaned.... I forgot how many times now and I would think that if it was the coil it would show signs while it was running when it was hot by missing and what not. The only other conclusion I have thought of would be vapor lock. When you go to try and start it again when it is warm it is definitely getting gas because if you pull the choke you can smell the unburnt gas from the exhaust.
It was too hot today for me to really mess with it while the engine was warm. I will have to wait till a cooler day.
I'd just slip a timing light on it to check for fire next time it does that. On my 2055, if you remember, I had a similar problem & actually heard the fuel in my carb boiling after shutting down. I had to make my own heat shields for it.
Premium Member
Discussion Starter · #3 ·
I will definitely put the timing light on it again when it does it. I know with my hearing I wouldn't be able to hear the fuel boiling. I know the air filter needs replaced too but I don't think that would cause this issue. It has heat shields on the header pipes, might have to run another piece of sheet metal across the top of them to help keep the heat away from the carb if that is the problem.
I remember, you had a loose coil wire on this one right?
Have you tried a different coil?
My MF14 had similiar issue ayear and a half ago, and Dan steared me in the right direction, and in the end it was
the coil. When it got hot, it was an epic failure.
Premium Member
Discussion Starter · #5 ·
I would think though that if it was the coil when it got hot that it would do it while it was running also. It runs great hot as long as I don't shut it off. I just went up to start it so I could put it in the garage and she fired right up. I tried to park it in the garage earlier but it wouldn't start since it was still hot/warm.
I will mess with it some more tomorrow when I have some time and get a timing light on it once it is hot.
1 - 5 of 5 Posts
