1 - 7 of 7 Posts
JD 110, 140, 212, 317, 318, 455, 755 & MF 1655
I need the specs on the rear PTO drive pulley for a MF 1655 that is straight off of the top shaft. Looks to be 3"-4" Dia. Pictures would also be awesome.
I will try to snap some pics when I get home this evening if I can remember, I have the whole assembly off a parts tractor lying on the floor.
would you happen to have a dash off of that parts tractor that you would be willing to get rid of??
Sorry I wrote that wrong, I got it from a parts tractor someone was stripping so no I do not have an extra dash. He did have a near perfect one and good steering column, but I was short on money, had to choose the parts I really needed.
Since mine is all apart, I compared all the pulleys. It appears the rear PTO small pulleys are identical to the pulleys on the driveshaft right off the motor and the drive pulleys mounted to the flywheel side of motor that hooks to driveshaft. If you can find either of those pulleys, they will work on the rear pto.
1 - 7 of 7 Posts
