1 - 12 of 12 Posts
I am thinking of tranporting my MF 10 on a trailer and am concerned about the weight. Does anyone have an idea about how much it weighs? I have the manual but couldn't find anything about the weight.
Thank you,
Chauncy
Here are some weights I took out of the manuals. MF12 - 680 lbs., mower deck - 135 lbs., snow blower - 165 lbs., tiller - 140 lbs.( 180 lbs. with extension ), Johnson loader - 350 lbs., dump cart - 170 lbs, wheel weights per set ( four pieces plus bolts ?) 92 lbs.
I used my bathroom scales to weigh my 12G model once, wheel by wheel. Each wheel ran around 150 or under for the front and a bit more in the back.
Howard you weren't sitting on it were you. :D I like that idea...thanks
  • Like
Reactions: chances882003
MH81 you are right the 680 lbs. is for the MF12 Hydro.
So that should mean my 12Hydro will already have 100 lbs more than my 12 G and directly on the rear axle as well. Which also means the hydro driven by my boys will have the same final weight as the 12 gear driven by me. :rolling: :rolling:
That ALSO firmly decides which of the two tractors will be need to have it's wheels removed to be put in the back of my pickup (has a cap/topper) :wallbanging: and which will remain intact and will drive onto the trailer on it's own power!! :smilewink:
  • Like
Reactions: MH81
1 - 12 of 12 Posts
