1 - 20 of 53 Posts
Discussion Starter · #4 ·
If you go to the manuals there's apic in the 1967 full color manual.
I have a 1 page 2sided black and white sheet on it I will try to put it in the manuals later today
Thanks.
That's the picture I had in mind.
I've got it downloaded now, and stored in a safe place.
If you do have anymore info about it, that would be appreciated.
Wheel Tire Plant Vehicle Tractor
That a pretty neat idea ! I wonder how they unload the compressors on gas driven units ? Do they have governors like our trucks air brake compressors ?
I've never actually seen one on a tractor before.I have this attachment on my wish list,so i'm looking for one.I wonder if they ever sold any?
Discussion Starter · #16 ·
I decided to build one.
In the one shed, I found a good tank.
Musical instrument Motor vehicle Automotive lighting Gas Tints and shades
And in another shed, I found an old compressor, which
I tested, and it works good.
Motor vehicle Automotive tire Wheel Valve Gas Automotive tire Motor vehicle Gas Engineering Machine
It's an old DeVilbiss. That rectangular cap, above the crankshaft bearing, is
where you add oil. It flips up.
I've got the frame welded up, tank modified with mounting brackets, and an
unloader valve on order.
Tire Wheel Automotive tire Motor vehicle Tread Wheel Tire Motor vehicle Tread Automotive tire
Wheel Tire Automotive tire Motor vehicle Vehicle Wheel Tire Motor vehicle Automotive tire Vehicle
Next, will be the clutch/tensioner and belt guard. I may make it different, so
it covers the engine pto pulley too. That's a nasty pinch point.
Looks good, Will! See, that old tractor has come in handy already! You can use it to build things for the pretty ones!
  • Like
Reactions: IamSherwood
Fun With Horsepower
That will be real handy Will. The area beside the pump could be used for a small reservoir. When connected to a cheap blow-gun with syphon tube attachment*, you can paint, spray insecticide, soap etc--virtually any liquid, where-ever you can drive the tractor.
I cleaned inside my diesel fuel tank with air and syphoned diesel last week. I couldn't remove the tank and didn't want to wash it with soap and water.
* Harbor Freight about $10
Discussion Starter · #20 ·
If you used swivel fittings on the ends (like through the bung drain opening) it could double as a front-mounted lawn roller with a bit of fab work.
:poke:
Yeah, thaaaat's thinking...... :poke:
But, I could add a "U" shaped pipe fitting thingy, with wee little holes
in it, and use it to blowdry the sidewalk after a rain....
1 - 20 of 53 Posts
