1 - 20 of 29 Posts
What would that third valve have been used for?
To power something like a woodsplitter, or? Not much psi there
for something like that. Did it have a detent position?
Looked it up at Agco, and the 3rd spool kit did not have a detent. I find no references to any attachment that would utilize the 3rd spool, nor remotes.
Possible uses for the third valve:
- Angling a blade, front or rear
- Snowblower chute rotation or tilting
- Hydraulic trailer dump.
- A separate hydraulic lifting device for the tractor or one end of a car or truck.
- A cherry picker engine hoist.
- Any task that a bottle jack will do, provided a proper base plate and cylinder support are used.
With a pressure of 700 psi, many things are possible. A 2" cylinder will lift 2200 lb on extension, 2.5" will lift 3435 lb, and 3" will lift 4950 lb at a rate of 1.4" per second at WOT, or 0.47" per second at idle.
Remotes aren't all that difficult to install. JD does it on all of their H3 tractors. Remotes can be Teed to the front and rear so that an attachment can be connected at one end or the other as required.
------------------------------------58
Reservoir capacity will accommodate 231 cu-in of total rod volume (diameter X stroke length). That is a lot of cylinders. Top up the reservoir when all cylinders are fully retracted and you're golden.
Then there are the tasks that can be done with a hydraulic motor, even with low relative flow and pressure. A winch comes to mind. Bear in mind that you have up to about 1.5 hp available for motor duty when the tractor is stationary. Less if it's moving.
What seems odd to me is Massey allowed for a 3rd, even though they didn't offer anything to utilize it. That is of course a good thing, that they looked ahead for YOU. Most manufacturers only add options that allow for using their attachments.
Oops! Correction!
The volume available for cylinder rod displacement of fluid from the reservoir should have been 58 cu-in, not 231 cu-in. That's still a lot of cylinders.
I agree, Dan.That's one of the advanced thinking items that I appreciated when I first saw these tractors in the showroom.
I just wished that they'd carried that type of thinking a little further and added power steering!
Oops! Correction!
Yes, quite a few extra cylinders! This is where it's important to use double action cylinders whenever possible. Single action require lots more fluid capacity. Most anything we all add to our GT's is double acting anyway.
Discussion Starter · #8 ·
And, looking through the price list, and brochure (in manuals here) there is no mention of the 3rd
valve, is odd too.
Have you found a source for the third valve spool? I'm building a hydraulic dump trailer that it would be really useful for! I've only seen 1 Massey 1855 that had the third valve, but never had a chance to talk to the owner.
  • Like
Reactions: IamSherwood
Discussion Starter · #10 ·
No, I don't have a source. I was just wondering. I've never seen one on a machine.
I suppose it'd be worth a call to a MF dealer to see if there are any out there.
The same valve sets were used on many loaders manufactured in the 70's and 80's, maybe the '90's as well. Several brands of GT's also used the same valve sets. There are minor differences in the porting, but they're all the same stackable valve sets. I believe they were made by Cessna.
I bought a set from Sears parts 30+ years ago. Most recently, I got a set from ebay a couple of years ago.
Anybody have a pic of these valves? The Sears FF has what is supposed to be a stackable valve on it. May be the same thing.
Here are two from Wheel Horses.
http://www.ebay.com/itm/Wheel-Horse-Tractor-Lawn-Mower-D-200-Hydraulic-Control-Valve-/201190069535?pt=LH_DefaultDomain_0&hash=item2ed7dcd51f#ht_1417wt_716
http://www.ebay.com/itm/Wheel-Horse-D-200-D-180-Tractor-Hydraulic-Control-Valve-/201166589531?pt=LH_DefaultDomain_0&hash=item2ed6768e5b#ht_1532wt_966
Note: As well as different porting, the levers may not attach in the same configuration that your application requires. This may require that you machine a new part to match the ones on your tractor to have the levers work correctly. I machined one from a piece of 1" diameter aluminum bar stock using my drill press, a router bit, and a cross slide vice.
It's not pretty, but it does the job.
Glad I found an extra set of valves.....I can do some stacking and add on.
Not sure what I will add on though :D I plan on putting the FEL on my other Snapper/PK
Sorry to dig up an old post. I am working on installing a 3 point on my 1855 this week. My 3 point spool is broken. If I have to dig into it I might as well upgrade it. Does anyone have an idea of a drop in easy installation 3 spool valve?
All I did when I added a spool was took one off a spare I had. Just needed 3 longer bolts and your good to go.
Yes, that's all ou have to do. Take the outer cap off and add a spool,then bolt your end cap back on. Don't forget your plastic washers in-between your new spool.
Sounds like the same valves the FF's have.
1 - 20 of 29 Posts
