1 - 4 of 4 Posts
Have a Snapper 1650 sitting in the shed. Turns over but has not been started for two years. It has the two rears and one front that won't hold air. No battery. Starter switch is bad, and needs a needle valve. It's rough looking but would like for running through the woods to fetch deer when I get one without scratching my good tractor. The cost of replacing the rear tires was always the issue as I didn't want to invest must more than $150 to get her back. The rear tires and battery are the high dollar issues and were stopping me. Just have a friend give me two turf Carlisle 23 x 9.5 x 12s with 80% tread that hold air. Also, it had an old battery that will be good to avoid the core charge. I think I will start with the starter switch when I get time and borrow the battery out of the good tractor to get it started. Then the carb. The rest should hopefully be easy. Hardest part may be digging it out from the back of the shed and don't know when I can get back to it. (The 3 point has been moved to a better tractor)
Could you just tube them?
  • Like
Reactions: boyscout862
1 - 4 of 4 Posts
