1 - 9 of 9 Posts
Deceased
OK, I'm needing some help.
As I've posted, the FEL on my newly purchased 1886 has single acting lift cylinders.
I need to replace them with double acting ones.
BUT, I need to know what to look/ask for when finding them.
Just how are hydraulic cylinders measured?
I'm assuming the the length of the stroke is one parameter, but what other measurements do I need?
Collector of Rusty Junk
The diameter of the cylinder. Also the style of ends.
Deceased
Discussion Starter · #3 ·
OK...and what are the different styles/types of ends?
As you can tell, I am completely clueless and I need to be edumicated on these things :D:D
Well there's tie rod ends which are more common, theres's welded Tube ends and welded clevis ends these can change the overall length of the cylinder.
Critical dimensions would be.
Stroke, bore, pin hole center to center when retracted. Port size and location. Pressure rating.
Could you post a picture of what you have, and of the ID plate on it, if there is one.
That might help.
Deceased
Discussion Starter · #6 ·
I'll take a look/pics tomorrow and post them here.
Here's a side view of the tractor in question from a distance if that would help.
It shouldn't be too hard to find DA replacements for those. It will make a big improvement in the loader to have down pressure.
1 - 9 of 9 Posts
