Well. I’m sick of the original Tecumseh 10hp in my MF 10. So the repower has begun. A repower I’ve done on 5 other tractors [Simplicity/AC, & a Cub] however this one seems to be going much smoother than the others. Found a Cub Cadet with a Kohler Command 16hp in it for DIRT CHEAP. And it runs like a dream.
NOTHING has been modified - not the frame, the hood won’t need to be, I’m able to use the original gas tank, as well as the Variable Drive Pulley from the Tecumseh - with the purchase of a crankshaft sleeve. I’ve got a belt ordered [had to get a new one since this engine pulley is a bit further forward than the original], once that arrives I can get the engine officially mounted in place. New throttle & choke cables should arrive this week as well. Needed longer ones since the connection on a Kohler Command is in what is now the “front” of the engine. I’m trying to find a muffler similar to what originally came on the Tecumseh to modify for the command, and that is most likely going to be the difficult part. I’m hoping to have this done for GT DAZE mid July. And have it on display with the 2 remaining Command Repowers we have here in our collection.
