1 - 17 of 17 Posts
hello new to the forum, recently picked up a mf 12 and was wondering since i cant find a 630 blade and mount for the life of me has anyone successfully adapted a newer or other brands blade onto the massey? Any push in the correct direction to a how to or even a 630 setup forsale is appreciated!
thanks :rocker2:
Premium Member
mtcrsst199, Welcome to GTtalk. One of the M/F guys will be along shortly to answer your questions. Post some photos of your Massey when you get the chance.
Hi.
Welcome to GTT. :wave:
Here are a couple of pictures of blades. The first ones are of an early model. 66-67.
in the 3rd pic, you can see the guide bracket that bolts to the front bumper.
Wood Gas Hardwood Brick Flooring
Wood Floor Flooring Asphalt Road surface
Automotive tire Wood Bicycle tire Tread Bumper
Here is a later version
Plant Wood Grass Groundcover Tree
You can see here where someone welded brackets to the front bumper for extra
strength.
Tire Wheel Plant Vehicle Tractor
Be patient. They do show up on ebay. I saw one there not long ago.
Freedom is not Free. Thank those in uniform for yo
Welcome to GTt and good luck with your conversion.
Hi.
strength.
Will,Just out of curiousity how do you know the year of the blade? Is it by the serial #? I never really looked into that.Are they numbered like the tractors?I'll have to look at mine.
Sorry my photos are dead links...
This may help out a bit!
Wheel Tire Automotive tire Tread Vehicle
Wood Bumper Automotive exterior Gas Auto part
Automotive tire Bumper Hood Automotive exterior Wood
Tire Wheel Automotive tire Tread Synthetic rubber
Automotive lighting Bumper Gas Automotive exterior Auto part
Gas Wood Plastic Metal Auto part
Hand tool Wood Metalworking hand tool Household hardware Handle
Wood Gas Metal Pipe Building material
Motor vehicle Bumper Automotive tire Cylinder Fender
Oh... and she looks all pretty, but that plow blade was mighty rough!
Automotive tire Gas Engineering Nut Auto part
Automotive tire Bumper Rim Motor vehicle Automotive exterior
Automotive tire Wood Gas Screw Nut
I had to rebuild a lot of the pivot system to make it work!
Automotive tire Bumper Hood Automotive exterior Tread
Automotive tire Motor vehicle Automotive exterior Bumper Automotive wheel system
Scale Bumper Wood Automotive exterior Gas
Tire Wheel Automotive tire Motor vehicle Tread
I also built another one for a friend.... I really liked this mounting system in the rear a lot more and built it to kinda help plan out brackets that could also be used for a sleeve hitch set up. The only problem with this one is that it was a bit too stiff and with the front mount being a little tight!
However, that rear mount is pure beauty if I do say so myself! I even custom turned the mount pin on the lathe!
Wheel Tire Automotive tire Tread Synthetic rubber
Tire Wheel Automotive tire Motor vehicle Black
Product Automotive tire Rectangle Composite material Gas
Grille Hood Automotive tire Automotive lighting Tire
Automotive tire Automotive exterior Bumper Motor vehicle Gas
Motor vehicle Rectangle Gas Automotive tire Machine
Rectangle Gas Auto part Metal Nickel
Automotive tire Automotive design Wood Bumper Motor vehicle
Automotive tire Motor vehicle Automotive lighting Rectangle Automotive exterior
I don't think they have a serial #. The 1st one I pictured in my post has the 2 pc push tube, and came with an
early 1967 MF10. I guess that model of blade could have been used longer than I said.
1 - 17 of 17 Posts
