1 - 11 of 11 Posts
Hi;
I have a mf 12 variable speed garden tractor and I am going to put a new neoprene rubber on the band and I was wondering what I kind of adhesive can be used to glue the rubber onto the stainless steel band .Thanks for any info
Welcome to GTT. I do not know the answer to your question but, someone will be by to help. In the mean time, checkout the galleries and Manuals Section. Three free downloads per day. Post pics to show off your treasure and when you have a question. Good Luck, Rick
Rubber?? I've had brake shops put new lining on some of my old stuff, but Rubber? You sure not just grease soaked brake material that looks like rubber?
I would go visit a roofing company that installs rubber roofs. Bring the parts with you and ask them to put the adhesive on the parts for you. Gene
Hi.
Welcome to GTT.
Sorry, but I can't answer your glue question.
As glgrumpy said, rubber seems like a bit of an odd choice. IDK
If you do some searching in the MF forum, you should find a thread about
brake bands. It was discussed in length, not to long ago.
I may have a spare, if you get into a bind.
I use automotive goop to hold my pads and bands on with. Noel.
I used brake band supplied by Salem Power Equipment (tel: 734-649-1781, www.salempwr.com). Ordered over the phone, a foot of 1 inch width material (5/32 ins thick) cost $22, including post to Canada. They specified it on the invoice as "C33427: Case Ingersoll Brake reline material". Stuck it on with two part epoxy using the brake drum as a former (similar to cheluIS's technique). Seems to be holding well enough after a couple of years' use.
Discussion Starter · #10 ·
Hi: I wonder if a massey ferguson dealer would sell the real brake lining for a variable speed mf 12 or do you have to buy the whole brake band.
Don't they have brake shops in CA? Take you band in with old liner for size, have them put it in with adhesive, and I like a rivet or two also myself and should be good to go. Not that expensive! Why can't you buy the band and liner as one? Can't really be that much more and save lots of frustrations if still available. If not, the shop is best next choice in my opin.
1 - 11 of 11 Posts
