1 - 3 of 3 Posts
I'm looking for a new, or good used hydraulic cylinder that lifts the mower deck on a Massey Ferguson 16 garden tractor. I believe the snapper part number to be 7019565. My cylinder is leaking from back of cylinder at anchor end, not ram end. Local hydraulic shop is going to soak me $350.00 to rebuild old unit. I was thinking that I might find a good used unit, or new old stock cylinder for less. I have looked around the net a bit, and best I can find is a "o" ring kit. "O" ring kit might do the trick, but I 'll look kind of silly bringing cylinder back to same hydraulic shop if "o" ring kit doesn't do the trick. Was just thinking that someone may have a good useable cylinder for less money. Thanks MH44d.
I have a cylinder off from a MF14 or a 16. According to the parts books they are different part numbers but I think they should be interchangable.The stroke should be the same for both as should be the hose fittings. Let me know if you are interested.
1 - 3 of 3 Posts
