1 - 4 of 4 Posts
Looking for replacement parts for solenoid part # 533 318 M91 and circuit breaker part # 530 180 M1. Also if anyone is familiar with CB how is it reset.
I installed a 30 amp slow blow fuse in line. The solenoid is just an automotive starter solenoid. Carquest BWD #S5049P
I went through everything on mine and it turned out to be bad Battery cables that had just enough contact for the lights or a click on the solenoid sometimes. They took 2 years to finally fail to the point that it would not start at all.
The breakers are auto reset. If it does not it is bad and can be had from any auto parts store same as the solenoid. I would go with 30 amp. Do not run the starter motor throw it.
1 - 4 of 4 Posts
