1 - 5 of 5 Posts
I have recently purchased a MF 1655 . Seems to be a solid machine, but it has a problem with the hydro static drive pedal. It doesn't have a nuetral centering point. What is used to center this pedal? spring or springs? where can I get them?
Thanks
It has springs, but not ordinary style. Not sure if they are still available or not. Maybe someone else that knows for sure will post the answer.
Premium Member
When I first bought my MF 1655 it didn't have any netural on the pedal either.The problem wasn't anything to do with the spring.The problem was that of a internal roll pin being broken. What you can do to see if your's is broken is to do this. Take the center cover off and watch the linkages.The pedal on the right hand side moves the linkage on the right side of the hydro that moves a shaft that goes into the hydro pump..It must be OK as your tractor has movement.Now on the the oppisite or left hand side of the hydro is another shaft comming out of the hydro with linkage connected to it.The left side has the centering spring and linkages on it.When you move the FWD?REV pedal the centering linkages on the left side should move as well.If there not moving then the roll pin that holds the shaft to the swash plate is broken.If thats the case then you'll have to pull the pump apart to fix it.Try not to use it that way as if the pin is broken its going to be putting small pieces of metal etc: into your pump etc.Larry
Discussion Starter · #4 ·
Thanks for the information. I will check out the linkages but I hope its just missing springs rather than pulling apart the pump.
Stan
Premium Member
It's actually only a single spring that has hooks on either end.If your spring is missing let me know and I'll take some pics of mine and measure it up and I'am sure you could very easily make one.It actually just pulls two linkages/levers back together centering them.Of course the creep adjustment is on the same side just about the spring.Larry
1 - 5 of 5 Posts
