1 - 11 of 11 Posts
Anyone have a parts manual for a MF 4810 Mower deck. It is mounted to my 1650. I blew out the bearings in one of the pulley shafts. I believe one of them is a 6205-2RS. If this is correct what it the other one? Also do you know a source for them?
I live in Owen Sound Ontario Canada however I really don't care where I get them as long as they are correct.
Thanks, Frank
Yes, the 6205-2RS is correct. I'll look the other up & get back with you.
WOW....Partspring wants $23.72 for each needle bearing! This Partspring place sure is out to scalp people!:mad2:
Discussion Starter · #5 ·
Thanks olcowhand. Ok so that means I need the 6205-2RS and the 3020679M1? Do you by any chance have a pic of how and where the bearings go. I assume one at the top of the shaft and the other at the bottom.
Thanks, Frank
The 6205's go at the top of the spindle, with the needle bearing at the bottom. For an exploded view, go to Agco here: AGCO Parts Books
Sign in as guest, then to Massey Ferguson, then Parts, then "grounds equipment". Scroll to find your deck, click on it & you will get the parts lists & exploded view of all parts.
Daniel, Is there any way you can copy that manual? I tried to log on and get it but it said I had to have Microsoft Silverlight. When I tried to load it I was told Windows XP did not support it. Would appreciate it if you could. Thanks.
I haven't been able to log in for a few months now. I don't know what's up with that, as others are able to as guests, and I'm registered with Agco! The Agco site needs Internet Explorer to view it. For some reason I can't no matter what browser I use.
You should also replace th dust shield at the bottom too. Massey part no. is 3020680m1 although I payed $15.00 Can. probably get them cheeper online.
You should be able to get 6205 bearings at any local bearing house. They are a standard bearing used in many applications. I think Princess Auto even carries them for about 5-6$
1 - 11 of 11 Posts
