1 - 2 of 2 Posts
I have a great functioning MF 650 tiller, everything is complete it has had the width extension on it since day one it has the spline shaft at the pto box and squared shaft at the tiller. I have restored my 1967 MF 10 two years ago and have slowly attempted to restore the implements. Though the tiller works great, I do plan on restoring it over this winter, i.e. sandblasting, powercoating etc.. I was wondering though I have not tore the unit down yet if there is any way to replace the bearings on the tines, seals, etc.. And if so what size are they. Thanks.
You can look at these better at agcopartsbooks.com
Sign in as guest, enter 12 or 10 as the model #, select MF from the drop down list.
Then you can look at the parts breakdown for the 650 tiller. You could check with
a massey dealer for those parts, but I would think you should be able to get brgs
and seals, from a good bearing supplier, just by giving them dimensions.
1 - 2 of 2 Posts
