1 - 12 of 12 Posts
trying to get dust caps off, front right wheel needs a new bushing any idea's i have started frame up i looked the frame over and it looks excellent no issues, so i have started sanding down parts for paint still have a lot to go as far as the sanding goes but could use some help with the dust cap let me know
thank you
take a plastic hammer and tap on each side as you try to pry it off with a screw driver. Just don't hit it to hard or you will dent it.
I've found, sometimes they might be out of round a bit, and if you
rotate it a bit, and then wiggle it with slip joints. Keep rotating it
till you find the sweet spot.
Discussion Starter · #10 ·
thanks again for all the tips they were very helpful dust caps are off and the sanding continues thanks again
1 - 12 of 12 Posts
