1 - 5 of 5 Posts
Electric Tractors
I spent some time today trying to see if I could put JD wheel weights on Massey front rims without the weight sticking out.
I got a pair of Jd weights, 35lbs each.
Food Tire Automotive tire Ingredient Cuisine Wood Circle Button Ball Flying disc
The front tire size on MF10,12,14,16 is 16x6.50x8, some have narrow rims, here I am using the wide rim.
Here's a rim, the weight and what I want to end up with.
Automotive tire Ingredient Food Gas Wood Food Tableware Ingredient Recipe Dishware
To do this I had to drill 2 mounting holes and 1 hole for the tire valve to move it to the inside of the rim.
Outside
Automotive tire Wood Vehicle brake Rim Gas
Inside, with hole for tire valve and mounting bolts.
Automotive tire Wood Wheel Vehicle brake Rim Automotive tire Wheel Wood Rim Gas
Finally the weight bolted in place, tire valve and grease fitting on the inside.
Road surface Wood Asphalt Audio equipment Circle
Tires I'm using are V61 with tubes, like these.
Wheel Vehicle Tire Automotive tire Tractor
This will be done on a good pair of rims that I have and go on my MF16 tractor that has the 3 point lift on it, 70lbs extra weight on the front should help to hold it down.
Looks good to me, Doug! Should work well!
  • Like
Reactions: DH1
1 - 5 of 5 Posts
