1 - 4 of 4 Posts
Electric Tractors
Found this in my part's box today I believe it is the bracket for the power lift. If someone knows for sure please say.
If that's what it is and someone has a need for it let me know, I won't be using it.
Yes, that's what it is. I just picked up a mf12 that had the power lift option on it and it has that bracket. There were two versions of the power lift, one had a belt driven hydro pump and the other had a electric hydro pump mounted on the lift cylinder. Mine had the electric pump but unfortunately the pump/cylinder are missing and a manual lift handle was installed. The switch, solenoid and wiring are still there. I checked them out and they are working so i am going to try to find a pump/cylinder for it. If I can't find one I should be able to use a linear actuator with the original switch, solenoid and wiring. I probably won't get to it until winter, summers are very busy for me.
1 - 4 of 4 Posts
