1 - 20 of 58 Posts
Hello,
I'm sorry but I do not control your language. I go through a translator.I live in France and I have businesses renovating a MF10. I completely removed and repainted.I'll go back and I will contact you if I have problems. Your site is very good.
Thank you for all your article and documentation.
good evening
Patrick
PATLULU! Welcome to GTTalk! I'm glad that we were able to help with information for your restoration! Looks like you're doing a great job so far! Please visit again and post some photographs when you're finished! Thank you for signing up and letting us know that we were helpful. It's always nice to hear!
GT Fanatic
Welcome to GTtalk Patrick!
Thanks for showing us your work on your MF10. I hope you will continue to keep us informed of your progress.
Bienvenue à GTtalk Patrick! Merci de nous montrer votre travail sur votre MF10. J'espère que vous continuerez à nous tenir informés de vos progrès.
Discussion Starter · #5 ·
I have a problem, I just paint the chassis in metallic gray paint but does not shine and it is especially rough. This painting is the original gray flintgrey MF brand Wilckens. I wonder what is the reason for this problem. Namely, this paint is very heavy particles.
I must find a solution. May be a veneer?
Bonsoir
Patrick
Was this paint in a spray can or is it paint that you add hardener to?
I agree with MH81 that it sounds like too much hardener in the mix. That would prevent the paint from leveling before flashing causing a rough surface.
Bienvenue sur le site de Patrick. On dirait que vous faites un excellent travail pour restaurer votre MF10. Il y a beaucoup de personnes sur le site, qui ont beaucoup de connaissances sur les tracteurs de jardin Massey Ferguson et sont toujours prêts à aider. Merci pour les photos et Veuillez publier davantage lorsque vous restaurez votre tracteur.
Welcome to the site Patrick. It looks like you are doing a great job restoring your MF10. There are lots of people on the site who have a lot of knowledge on Massey Ferguson garden tractors and are always ready to help. Thank you for the pictures and please post more as you restore your tractor.
Discussion Starter · #9 ·
hello,
I use to paint a gun. I put the hardener but on some parts, I used the paint without hardener. I just noticed on the pot that date in August 2009. What is the shelf life of a synthetic paint in its original pot sana opening it?
This may be the problem??
Patrick, soyez bienvenus au forum. Content de vous avoir avec nous.
Semble que vous fassiez un travail agréable sur votre MF10.
Patrick,welcome to the forum.Glad to have you with us.
Looks like you are doing a nice job on your MF10.
Welcome to GTTalk! I can't answer your question on the paint, but wanted to say Hello! Hopefully someone will be able to answer it for you. Did you thin the paint at all?
I did a little research and found that the unopened shelf life will depend on the type of paint. Urethanes or epoxies will store well unopened, enamel paints may not. Check the paint in the can for sedimentation and uniformity, they can be evidence that the paint is curing and then is not usable.
J'ai fait une petite recherche et trouvé que la durée de vie fermé dépendra du type de peinture. Uréthanes ou époxy va stocker et non décachetées, les peintures-émail ne peut pas. Vérifiez la peinture dans la boîte pour la sédimentation et l'uniformité, ils peuvent être la preuve que la peinture est le durcissement puis n'est pas utilisable.
Discussion Starter · #13 ·
Good evening,
I am in contact with the seller to find a solution. I plan to spend a polyurethane varnish but is it compatible with a synthetic paint?
Patrick
I cant help with the paint issue, I just wanted to with you the best of luck on your restoration! Welcome to the forums!
Je ne peux pas aider à la question de la peinture, je voulais juste avec vous la meilleure des chances dans votre restauration! Bienvenue sur les forums!
Discussion Starter · #16 ·
Good evening,
Could you tell me how I can add more photos as it seems to have no more space?
thank you
Patrick
Premium Member
Good evening,
thank you
Patrick
You should be alright now to upload more pics. I forgot a zero in the setting and it should have been 100mb for new members but it was set at 10mb. Once you hit 10 posts you will automatically be moved from the new member group to the member group and the limits will be raised.
When I am sending pictures to a forum, I will usually use a program called Image Resizer from Microsoft. It is a free program for XP and works very well. It will turn those very large pictures to a file that is around 250-500Kb (depending on your settings) and takes up much less room in the system. 100M is a lot of room 250kb at a time.
Discussion Starter · #19 ·
Good evening,
I solved my problem by putting paint a layer of synthetic varnish. I finished the renovation of the engine. I am attaching pictures.
Is anyone have the wiring diagram of the headlights of an MF10 1971 because there code, lighthouse, night light and a switch.
PATLULU, Thank you for the pictures! That looks great! I'm glad that it's coming together for you. May I suggest using Google translate for your posts in the future, as it seems that your syntax doesn't translate directly. I believe that you're seeking a wiring schematic. You can find that Here. I hope that this helps!
PATLULU, Merci pour les photos! Cela ressemble beaucoup! Je suis content que ça vient ensemble pour vous. Puis-je suggérer en utilisant Google translate pour vos messages à l'avenir, car il semble que votre syntaxe ne se traduisent pas directement. Je crois que vous êtes à la recherche d'un schéma de câblage. Vous pouvez trouver ici. J'espère que cela vous aidera!
1 - 20 of 58 Posts
